Qn.1 Both starboard engine mount has rust on the base plates and the rubber at plate is lifted. The supporting rubber are still ok as far as I can tell. Port side are good and no rust.
Question is can I just change 1 or both of starboard sides (condition depending) instead of all 4 pieces?
Engine is 18 yo Yanmar 2GM20F.
Qn.2 One of the mount Lag Bolt hole is stripped. Any advise on how to repair the hole? I'm thinking of filling it with match sticks or similar thin strip of wood and with wood glue. Not sure which make/type of wood glue or wood putty or .....?
Thank you.
Ken Y
Thank you.
Ken Y
