Neww to me sailboat has an outboard, and the pivot pin is corroded or just extremely tight. been playing with it off and on since I picked it up to get it so it was easier to turn. (two hands from outside the boat, won't try the tiller)
I've never owned a sailboat with an outboard before, every one I've owned has had an inboard, or no motor at all.
Several people have mentioned that there is no need to turn the motor, (because sailboats have that nice big rudder) which when looking at the outboard well, it would only allow a very small range of movement with the tiller down, making the rudder steering sound plausible. Complicating the issue, is that I've found a few posts where people are using a tie bar to allow turning the outboard with the tiller, because the outboard tiller is too hard to use.
So the question is, when steering under power do you use the motor or the rudder?
The boat is a portager 22, and the outboard is a chrysler 10hp longshaft 'sailor'
Thanks
Ken.
Thanks
Ken.
