Silicone Heater Hose
DArcy
Feb 11, 2017
1,786
Islander Freeport 36 Ottawa
The hose from the water pump to the water inlet on my Pathfinder engine needs to be replaced. It is a 1" ID heater hose, doesn't appear to be molded. I cannot find 1" heater hose locally and the only hose I can find online in Canada is Amazon,
the description is
MECCANIXITY Silicone Vacuum Tubing Heater Hose 1" ID 3.3ft 101psi 392F Red Reinforced High Temperature for Engine
Is silicon hose the way to go? Silicon tends to be more flexible so should be easy enough to install.
