Sikkens Cetol stain removal
Dec 2, 2003
209
Hunter 34 Forked River, NJ
OK, I was careless and spilled some cetol on the white fiberglass deck, I cleaned most all the excess, and a lot of the stain, but there is still a rather large 2 foot square stain I can't remove, any ideas?
dmax
Jul 29, 2018
1,219
Telstar 28 Buzzards Bay
Work your way up to the most aggressive to minimize further damage: Try prying it off with a razor blade/awl etc. if possible. Then try Mineral Spirits which should dissolve it slowly. Acetone is next and will dissolve it. Clean the deck after using either of these. Last, try sanding it off.
Nov 26, 2012
1,654
C&C 40-2 Berkeley
It sounds like it has soaked into the gelcoat. I will probably have to sand it off or use acetone to dissolve it off.
