Shurflo wrench - sea strainer
Jul 6, 2017
158
Hunter H 41DS Hampton, VA
Does anyone know of there is a tool made just for unscrewing the clear Shurflow raw water strainer bowls? OR a generic one that works really well. I have two size strainers; 1 for the ac intake and 1 for the engine intake.
Pentair Shurflo Raw Water Strainers
Thanks
Once the filter is open, try lubricating the threads with a little silicone grease. I've used the dielectric grease for electrical connections. Makes removal much easier.
Jan 4, 2006
7,441
Better than that, ensure that you lubricate the gasket on both sides with a NON PETROLEUM grease such as Super Lube to ensure the clear bowl comes off by hand next time.
In a pinch for now (and if you have one), use a strap type oil filter wrench but go reeeeeeeal easy on how much force you use. As a last resort, use the wrench recommended by @sail sfbay .
Likes: ggrizzard
capta
Jun 4, 2009
5,008
We just bought one and it is sitting on the table, so I took a look. With an o-ring like that it shouldn't need to be tightened all that much. If you have to, get a new o-ring. As said above a strap wrench would probably do just fine.
Oct 1, 2007
1,865
I simply tap the ridges on the bowl with a screwdriver and rubber hammer. They loosen up immediately. I hand tighten them going back on. Works fine. I will pick up the wrenches though. On my boat all the seacocks save one are in a "farm" under one deck cover. I'm not sure the wrench can be effectively used in that configuration. We'll see.
