I have just put the mast up on my boat and I'm not sure if the shrouds that run to the top of the mast are to be attached to the chain plates ahead of the shrouds that only run half way up the mast or other way around - If attached to the front chain plates the spreaders are at 180 degrees to each other if I switch them up the angle is more like 120 degrees
