shroud / turnbuckles
184
hunteer 23.5 st lawerence
Figured this might be the fastest way to get some information. I have bent turnbuckles on my 1993 h23.5 and am not risking another year with them. does anyone know when ordering what size, diameter, length I need to get ? they are the two on port side and two on starboard , attatches to shroud lines , thanks for any help
Jun 2, 2004
5,802
Do you not know the size of the wire on your shrouds? That is what dictates the stud size and thus the turnbuckle size. Someone here will know. My own 37 uses 1/4". I would guess 1/8" for yours but it might be 3/32". I know my friend's 28.5 is 5/32".
DJN51
Oct 26, 2009
377
Hunter 23.5 East Chicago In
Manual for my 95 23.5 says 5/32 0n all standing rigging.Try Vermont Sailing partners.Bill Fastiggi 802 655 7245.Great person,will do you right.If you have Manual it has all length and sizes.If not I can send you sizes as per manual.
Apr 27, 2010
1,279
Hunter 23 Lake Wallenpaupack
I got the standing rigging specs for my H23 from Hunter. The 23 happens to use 5/32 1X19 wire as well.
Jul 1, 2010
990
Catalina 350 Port Huron
It's 5/32 cable. I'm pretty sure the turnbuckles are 1/4". I just took one of mine down to my local sailing shop and matched it up. They had them in stock. Make sure you get the right thread. I seem to remember them coming in either right or left hand thread.
You can order the toggle jaws (the part that bends) here:
http://www.riggingonly.com/stdrig04.htm#TURNBUCKLES
