I have a bent lower shroud turnbuckle threaded T bolt and want to replace the whole turnbuckle assembly except for the end coming from the shroud line, i.e., the top threaded end of the turnbuckle. Can anyone provide the specs for a replacement turnbuckle with T bolt? I see in the Hunter manual that the line is 5/32" 1x19 SS ending in a turnbuckle, but what is the size of the turnbuckle: pin diameter, length, breaking strength and left or right hand thread? My boat is in the water so I don't want to take the item off and bring it to the store to compare it assuming they have one at all. Hard to believe these specs aren't listed somewhere already. Thanks.
