Hello folks,
I have recently bought a 98 capri 22 fin keel, standard height rig, race package boat that came with Gus mainsail and cdi furler (135 headsail on it)
I am ready to tune the rigging but have been getting conflicting advice on shroud tensions from local catalina owners, none are c-22 owners. Can you please share your experience and advise?
Opinion1: lowers should be 5-10% tighter than uppers because lowers hold the mast in column. Uppers should be less tight to allow the mast bend backwards above the lower shrouds in order to take advantage of fractional rig/split back-stay, while still holding the mast in column.
Opinion2: uppers should be tighter than lowers. Why: Uppers hold the mast centered left/right and carry the lateral load from the wind. Lowers limit the mast bend.
Your guidance is greatly appreciated.
Thanks,
John K
Thanks,
John K
