Brian
I have a new (2003) 260. The mast, as delivered by the dealer, is bent to port. The bend appears to be associated with the tension of the upper shrouds, specifically the section of the uppers that goes from the spreaders to the attachment point high on the mast. I currently keep the boat in a slip with the mast up. Question is: Is the entire length of the shroud tensioned from the turnbuckles at the deck, or is the upper section of the shroud (spreaders to high on mast) tensioned from a point on the spreaders? Looking up at the spreaders, it appears that the upper section of the upper shrouds may be tensioned from the spreaders.As always, your input is appreciated.Brian.
