Copied from another thread....
It's a process, not a number.
In general, the process is
1) get the masthead centered. You can do this with the main halyard, or by hoisting a 50-foot tape to the top of the mast. Either way, you want to check and make sure that the distance from the masthead to the base of the shroud is the same on both sides. Adjust the upper shrouds until the distances match.
2) then, sight up the mast and see if it is straight. If there is any bend to one side, adjust the lower shrouds until the mast is straight.
3) when the mast is centered and "in column", snug all the shrouds evenly. they don't need to be "tight" at this point, just not sloppy. In general, if you pull on one of the wires and it deflects less than two inches, it is plenty tight at this state
4) Then go sailing, preferably on a moderate day (8-10 knots, tops). Put the boat hard on the wind and see if the leeward shrouds are loose. If they are, tighten them a little, then *tack* and tighten the new leeward shrouds the same amount.
Repeat this until the leeward shrouds are snug when on the wind.
Then... lower sails and go back to #1. Check to see if the masthead is centered and the mast is straight under the masthead. If the mast is not centered, loosen one upper shroud slightly and tighten the other the same amount. If the mast is not straight under the masthead, loosen one lower shroud slightly and tighten the other the same amount.
Bottom line... tuning a rig isn't about hitting a number on a gauge - it is about getting the rigging so that it holds the mast straight and centered while you are sailing. The shrouds shouldn't be violin-string-tight, they should simply be adjusted until they support the mast correctly without any slop.
$.02
