Shroud Tension
1,015
O'day 30 313 Georgetown MD
The other day I noticed that when heeling the shrouds on the side that the mast was heeling to, were loose. When the boat is flat, the mast is centered (by way of measuring with the main halyard) and pretty taught. My question to the list, how slack should they get when healing?
Dec 16, 2006
353
Hunter 25.5 Cayuga Lake, NY
They should not be slack or loose when sailing. When tensioning your rig the last step is to go out in a modest wind and check for looseness to the leeward shrouds while sailing. Adjust both sides equally in small increments and recheck.
Oct 10, 2010
269
Hunter H260 Gull Lake
I seem to have a pretty sloppy roller furling. Is there some way to test it so I can have a figure to compare to. I purchased a Loose Gage but I can't figure out how that applies to a roller furler. Where can I find out what the tension should be and how do you set or check it.
Thanks,
mr c
Aug 4, 2010
77
hunter sailboat 31 northport
I was told slack on a B&R rig was ok. Should I get mine checked?
Dec 16, 2006
353
Mr C, think of it this way. If your leeward shrouds go slack or loosen under sail loading then your rig is moving from side to side. This is not acceptable imho. I wouldn't want my mast changing it's position every time I tacked. I'm on my 2nd B&R rigged boat btw. Find the tuning guide for your rig and follow their suggestions.
Oct 18, 2008
45
Jeanneau 49DS Seattle
It's ok to have a little slack in the lee shrouds as long as the mast stays in column.
Nov 8, 2010
11,386
Shanker,
There is no measurement for the furler. Set all of the shrouds correctly and the furling bar should be very tight. There is some adjustment of the lower mounting bracket. It screws into the furling drum.
http://www.h260.com/rigging/rigging.html
On a B&R rig, after the mast is raised you must make sure the forestay is snug before doing the final tuning. This is because the B&R rig is statically tensioned and does not pull on the headstay to create rig tension. If the forestay is too loose, the rig will tension against itself when tuned and leave the forestay slack.
Jul 1, 2010
990
Catalina 350 Port Huron
Doesn't the forestay adjustment just set the mast rake before the shrouds are tensioned?
Dec 16, 2006
353
Your boat, your rig, your wallet! I suggested "dilligaf" as a boat name once but was out voted by the commodore :) I do gaf about my rig tune so mine are never slack lol.
