Hi.
Ken's got a good approach. In addition to his first steps, then add: "Go sailing!"
That's the fun part. Go on a port tack and watch the starboard shrouds. You want the upper shroud to be "solid" and not flapping. Solid, not taut. The lowers can be just to the point of flapping.
Then flop onto the opposite tack, and do the same.
Many will suggest that you "only go halfway" on the first tack, but if you don't perform what I suggest, how are you going to know what those suggested "tensions' really should be, without having some experience or a gauge.
Then do some more sailing and sight up the mast both ways. Adjust a little bit as necessary for the next few sails.
Catalina published these suggestions in their boat manuals for masthead rigged boats for over 30 years.
It's worked well with me on a C22, C25 and now our C34.
Should work for you with yours, nice boat BTW.
Have fun.
Oh, and once you get it all set up, you can do more research and find a technique that works best for you. It's kinda one of those "art not science" (unless you're a racer).
That said, I subscribe to the theory that there is only one way to set sails: the right way not cruising or racing.
