The mast on my 23.5 above the spreader bends leeward in light/medium to medium winds and the lower shroud is loose to the point when a puff hits it you can actually see the slack in the lower shroud wobble. I researched the owner's manual and could not find the tension specs.
I doubt that the previous and original owner ever touched the shrouds except to replace bent left turn t-bolts. Does anyone know what they should be? A couple of knowledgeable sailors in my club have tuned rigs and have agreed to assist as they have the appropriate sized Loos gauge. I just need the tension specs.
Thanks for the help!
