So, I was researching shroud and stay tension. I do not have measuring gage nor do I have much experience. I just installed a furler (snapfurl) and need a good rule of thumb that'll get me closer until I can borrow a tension gage or some local experience. The fore and aft tension following the install is quite loose. The upper and lower shrouds have always been very tight and appear almost rigid on my 222 (both before and after the install). I now need to bring all the rigging closer to correct tension. Can some of you experienced folks provide some advice?
