Shroud Lines
John Gladstone
I've had some trouble with the shroud lines. When I'm sailing at a close reach and the sail is full, the shroud on the leeward side seems awful loose. It doesn't have any tension to it. Is this normal or are my shroud lines too loose? How can I make sure they are tight enough? Can they be too tight? Any advice would be appreciated.
