I want to rebed the shroud fittings on my ODAY 39. They are similar to U bolts that go through the deck and through an aluminum block where they are held in place with partially recessed nuts. A rod goes through the block and goes down to the grid in the hull.
The aluminum blocks show white corrosion but the 1/2" shroud fitting is seized in the block.
Has anyone disassembled the fitting and can give me advice on freeing the bolts?
Jack
Jack
