Shower Switch
Jan 6, 2013
8
Catalina 310 Toronto
I have a small on/off switch on my shower panel in my Catalina310, that has blown. I don't want to buy the whole panel which costs a lot. The switch is probably a $4 item. Does anyone know where I can buy this shower switch?
Many thanks George
Silvio
Dec 1, 2010
61
Catalina 310 Solomons Island, MD
You talking about the breaker on the panel or the switching the head?
West Marine carries breakers along with Catalina Direct and many other online retailers.
If you are talking about the rocker switch, when mine died I replaced it with an off the shelf one from West. Just cut the opening to fit with a dremel and done in 2 minutes.
Dec 25, 2008
1,580
catalina 310 Elk River
Have no idea what a "Shower Panel" is?
Do you mean the breaker panel, or the switch that is behind the head that controls the shower sump pump?
Jan 6, 2013
8
This is the switch in the head. I have rigged a temp switch from WM but would rather get the correct replacement. Thanks
Jul 8, 2011
704
Catalina 30 Sidney B.C.
I have not seen a switch with wire in it
I have replaced original switches on my bost with old rv stock I have collected and they are the same part numbers
Oct 18, 2008
45
Jeanneau 49DS Seattle
I replaced mine with a momentary on/off switch from WM. It works fine in the three heads I have on board
