I have a 2005 Catalina 400. The rear shower has an electric pump to pump out the water that accumlates in the bottom drain section of the share--this is a space that is below the floor and has a lid over it. The problem is that the pump only pumps out the water down to about two inches--thus I am alwyas left with water that I use a cup to take out.
Does anyone have this same problem and do you have any solutions or ideas. (Catalina had suggestued I drill a hole and let the water drain into the bilge-- but that makes the factory installed electric pump system useless-- plus I do not want shower water draining into the bilge) thanks, Steve
