Shower Floor Drain
Jun 13, 2016
21
Hunter 38 Mystic, CT
floor drain was leaking into the bilge. after taking it apart it appeared hose connection was OK but the flange of the drain that connects to the floor had no sealant or it had dried up.
I believe there should be some type of seal but concerned about using silicone should it need to be removed some time in the future.
Any recommendations?
Jun 13, 2016
21
Thanks for the response. I am familiar with butyl tape having used it in the metal roofing industry but hadn't considered it for this application.
It stays pliable so it sounds like a good use.
@jviss is a man of few words.... :plus: on his selection.
