New twist to a bilge hose..
I needed the bilge hose replaced on my 82H33and called on one of the local marina fixitguys to do it, because I didn't have enoughbeer on hand to try it myself, and all my hangers were plastic.He ran a single piece of thinwalled pvc pipefrom the bilge, under the flooring, straight to the cabinet under the sink in the head. He then clamped standard bilge hose to each endto finish the job. Very ingenious I thought,and it probably has less resistance pumping outthe bilge because of its smooth sides.You didn't say what you are sailing, Rad, buton the 82H33 the sump and bilge-pump for my shower drain is located under the batteries beneath the companionway. After removing the batteries, a 3/4" inch piece of marine plywood lifts off the top of the sump and you have access to the pump and the hose.
