Jeff Bacon
Hi All:My 376 shower drains into a sump, which is pumped out by manually turning on the pump. I have 2 problems........First, the sump dosen't hold a full showers worth of water, which means I have to lean out, turn on the pump, wait until the sump is empty, then turn the pump off. Then do a repeat performance if the sump fills up again.Second, the hole in the side of the sump where the wires and the pump discharge come through and attach to the pump cannot be adequately sealed to prevent shower water from leaking through and into the bilge. Not good !Has anyone devised an alternative to disposing of the shower water ? I was considering using the "wire hole" as a simple drain somehow draining directly into a container that I would place in the bilge, then pumping out from there. Bit not sure exactly how to accomplish this as underneath the shower area is virtually inaccesable.Anyway, any thoughts ????Jeff
