Shower bilge problems
1
2 33 ft nj
Can someone help me with this problem. The water will not pump out of the shower. I don't know the location of either the holding tank or shower bilge pump so I am having difficulty checking out the source of the problem.
Any suggestions? Thank you Tom
Mar 11, 2009
200
Hunter 40 Saint John
Hey Tom
Our Hunter 40 has had similiar issues, however the grate that covers our floor can be removed and you can see the bildge pump right there... What happens in our case is the check valve installed by hunter gets full of SHITTT, and it has to be taken apart and cleaned up... If you can find the pump and valve, I am sure that will be your problem ...
Dec 19, 2005
20
Hunter 36 Des Moines, WA
Hi Tom,
Our Hunter36 has a plastic "sea strainer" in-line from the shower drain to the sump pump. It keeps all the gunk (hair, soap etc.) from entering the pump itself. Every 6 - 8 showers we have to unscrew the top of the strainer and remove the gunk from the metal strainer. Fixes the problem every time!
