I'm curious about the fact that our rudder has about a half inch of vertical play. We noticed when we hauled the boat as part of the pre-purchase survey that there was a "bald spot" on the bottom of the hull above the rudder. It looked like the rudder had worn off the bottom paint in an area about two inches wide. A few months ago, when I removed the cockpit deck panel to access the radial drive wheel in order to see if I could attach a rudder position sensor, I noticed if I stepped on the radial drive, my weight would cause the rudder to drop a half inch, and then it would pop back up after I took my foot off it. Apparantly our rudder can move verically about a half inch, and its natural floatation is causing it float up and rub against the bottom of the hull. We don't notice any issue when we're under way, it doesn't seem to drag or anything when we turn the wheel. Anyway, is this a normal thing? Or is there something wrong with our bearings that needs to be addressed?
