Should I wax new gelcoat
V
Vic Brownjohn
Someone told me not to wax my new boat for the first year because the fiberglass gelcoat needs to set? Is this true? What about using cleaners etc. on new gelcoat?
A
A.L. ("Jim") Willis Pres of ISLAND GIRL PROD.
Mold Release is the best protection
The reaons you given were probably not the right ones but are on the right track - sort of!. As you know when the gelcoat that is sprayed into the mold does not stick because the mold is coated with a special mold release agent that contains (among other things) silicone resin which when it is set up is one of the most durable materials there is. For example heat-resistant paints use silicone resin (the heatfrom the stove or whatever cures the resin). That is why I cringe when I see brand new boats at shows being "buffed out" by a polishing wheeel. Even the finest grit polish or "liquid wax" contains grit that removes the original "bonded on" mold reelease protection and starts to ear away the surface and allow a better substrate for oxidation. Also, of course the wheel could catch some airborne grit and produce even more damage. I would advise a a completely non-abrasive approach. Either nothing or a "quick detail" silicone based product. Ou Silkenseal forms an even thicker,protective skin. Hope this of some help - I have been waiting to have a go at all the detailers who start to ruin boats from the very beginning by use of abrasive. Sincerely Jim WIllis
K
Kurt Schenholm
Waxing Gelcoat
Yes you should wax a new boat, The gelcoat doesn't have to set and as for washing I like Turtle wax wash wax, it helps it keep like new.
