Or something else?
I just finished making backing plates for my bow pulpit. I used 1/4" aluminum. I drilled and formed them so that they are a pretty nice fit. But they will be tightened up to the inside fiberglass of my boat. Of course it is not perfectly smooth, and way to much work to make it so. So my thinking is to use 5200 as a bond and filler for the aluminum to the fiberglass. I would bolt it all together until the 5200 has hardened then remove the bolts, clean the holes and finish installing with either buytl tape or Life Caulk.
I also have on hand some fiberglass resin, and feather fill. I considered the feather fill first but not sure how good of a bond to aluminum it would give.
What do you guys think?
