Took our 25.5 yesterday in light air yesterday. There is a wire cable with a simple spring loaded shackle at the end of the boom going to the top of the mast. This is keeping the boom roughly parallel to the boat. I'm thinking this prevented the mainsheet from being able to pull the boom down to tighten the sail. Once the sail is raised should I unclip the wire? I didn't think to try it yesterday but I'm thinking the boom would fall down a good bit (using original mail sail which is probably stretched out).
Also, is it worthwhile to add some type of topping lift/block to this wire to keep it attached but still enable to the mainsheet to pull it down?
Thanks!
Thanks!
