Bill Leathen
My crew is back in shool, and I can't believe I am planing winter lay up projects. This spring when we stepped the mast on our H23, we put a kink in the starboard outer shroud. We noticed the kink with the mast 1/2 way up. We lowered the mast, took the kink out, raised the mast and tuned the rig. With the rig tight, you can not see the kink. There are no broken strands in the shroud. You can run your hand over the whole shroud without fear of getting any little jags. But when we released the shroud to install some new shroud covers, the kink is still there when the rig is slack. My question is - should we replace that shroud? If we replace it, should we also replace the port side upper shroud, or should we replace all 4 shrouds, both the upper and lower? Your advise will be appreciated.Thanks,Bill Leathen
