Cherubini H-27
I traded my Columbia Contender for my 1978 H-27 in the spring and couldn't be happier. The PO had removed the one cylinder diesel (died) and replaced with a Johnson 9.9 outboard and I'm glad for after talking with lots of other H-27 owners, the yanmar was really not sufficient for the boat's weight. (If I were to replace the diesel, I'd opt for a 2GM.) As far as sailing characteristics, she is very stable, likes 10 - 20 knot breezes, anything over that it's time to reef as she's faster upright than with the rails under water. (That was my main reason to trade the much more tender, albeit FASTER Contender for an upright vessel.) Many folks have complained that the H-27 doesn't point all that well,but I've been very pleasantly surprised with our Ciao Bella in that respect. Coincidentally, my first sailboat was a Macgregor 222 pop-top that I had from 1972 to 1976. As I recall, it was VERY tender and suffered from less than top of the line fittings, (although she was also very fast), so I think the transition to a Cherubini design will not only give you the stability I mentioned, but also much more in the creature comfort area, particularly below decks. As to whether or not the Hunter is a blue water cruiser, I guess that depends on your sailing ability. Certainly, your present location indicates you've become accustomed to sailing outside of the sheltered waterways that I enjoy down here in Florida. Anyway, good luck! Neil SmithCiao Bella 1978 H-27
