I climbed down into the bilge yesterday to do some more scrubbing when I noticed the sunlight glowing through parts of the hull. Is that normal??
One the second pic, there are two pinholes that I can't even see from the outside. But they're barely above the waterline on a calm day. I've never seen water in the aft part of the bilge but they still make me nervous. What's the best way to fix a small hole like that!
Then I flipped around heading down the starboard side up to the bulkhead(?). Found some water in there which explains the squishy sound we here when we walk on the cabin floor. The wood is rotting. Is this something that needs to be totally replaced or should I just try it out and leave it in place?
