Short splice
Sep 3, 2012
29
Catalina 310 Marina del Rey, CA
On checking my anchor rode I noticed chaffing at 150 feet. I have 300 feet of 9/16 three strand nylon. I didn't want to buy all new line. I cut out the chafe and used a short splice. I read that a short splice strength is nearly that of the original line. Is this the case? and would you trust the splice to hold?
Thanks
Feb 20, 2011
8,023
Good eye. Maybe do a long splice? :D
And maybe even seize/whip the terminations?
Mar 26, 2011
3,583
Corsair F-24 MK I Deale, MD
A long splice is weaker than a short splice, since a strand is removed. The ONLY reason for a long splice is to go through a block. So long as you do not have a windlass, short splice.
A short splice will be as strong as the termination at the anchor end, which is not quite 100% either. No problem.
Two eyes? That's just adding more wear and failure points. Can't imagine a reason to do it that way unless joining 2 incompatible rope types or to break a very long line into more manageable parts.
Feb 20, 2011
8,023
Ah, I should have typed "longer", not "long"!:D
