Shorepower and running engine
Apr 8, 2014
12
Hunter 30 Fort Walton Beach, FL
Hi! I am new to this site and a new Hunter Owner :). I have a quick question.... when I am plugged into shorepower and want to start my engine (Yanmar 2GM20F) should I unplug the shorepower first before starting? I try to start her up every few days or so. I have "heard" that I should unplug first and several times I have forgotten to. Thanks!
Nov 6, 2006
10,100
No Need to unplug unless you are going out :~) There will be no problems from running a battery charger and your alternator at the same time.
Dec 2, 1999
15,184
Claude: If my cord is long enough can I leave it plugged in?:Liar::naughty:
May 6, 2012
303
Hunter 28.5 Jordan, ON
Although somewhat tongue in cheek, the previous posters make good points.
If you are going to be going out, make unplugging shore power a part of the routine (step one, do this, step two unplug, ...), and keep it the same every time.
Otherwise you will invariably forget sooner or later, and end up with one damaged cord end and fodder for your dockmates to razz you with. :)
Catalina 380 16 Rochester NY
Been there done that..I always have the same routine. A quick precheck of the chainplates and pins, a gaze at the sheets and halyards and then to the back to start the engine.
Once done, I unhook shore power, get off the boat, release the dock lines, hop on board and away I go.
I got side tracked with a passenger that wanted to help. I let him get in the way of my routine and forgot to unplug the cord.
Needless to say, when we backed out, the cord ripped the socket out of the hull and twisted the stern to starboard...the passenger went to grab the power cord until I screamed NO!!!! I had visions of 30 amps coursing through his body...
I went into forward gear, redocked quickly, undid the cord from the dock.
Thankfully, the outlet on the deck wasn't too bad, some new butyl tape and all was well.
That was the last time...now I make my guests SIT!!!! They mean well, but it's best to follow the same routine every time!
Have fun!
Chris
Welcome and congratulations on your boat.
Many times when new skippers are still plugged and charging, they write in that their tachs don't work. That's because if the batteries are full, the alternator's regulator won't send a signal to charge.
Good luck with everything. Look forward to seeing you here.
Johnb
Hunter 37-cutter Richmond CA
Not that this is relevant to your question, but please don't leave the dock end plugged in and unplug the boat end. We used to have a neighbor who left the hot cord lying along the dock, a totally unnecessary hazard.
Dec 14, 2011
316
Navicula 430 Hunter Toronto
Yes I agree never leave a live cord handing around......my routine is to unplug from the tower first then I disconnect from the boat...:D
Apr 11, 2010
976
Hunter 38 Whitehall MI
Also not completely relevant to your question but you said you start the engine every few days. Unless you are running it long enough to get hot and under load you could be doing more harm than good.
Getting an engine warm but not hot produces condensation inside the engine which can become acidic and damage the components. Engines need to get hot.
And diesels do not do well just loafing along at idle. They need to be put under load so as to avoid carbon build up in the cylinders.
Mulf
Dec 2, 2003
400
Hunter 410 Chester, MD (Kent Island)
Dreamboat's Checklist
When we bought Dreamboat I was a little overwhelmed by all the things I needed to remember to operate her. So I made up the checklist which is on the attached PDF. I have laminated it onto a double sided 8-1/2 by 11 sheet of paper and we go over it every time we use the boat. It's better than missing something as shown by the stories in this thread. I had to convert it to PDF to upload here. If you want the excel file email me at mulf(at)live.com
185
Catalina 27 Niceville, FL
I usually turn my battery charger off before starting the engine. I have forgotten, with no problems. It puts a large load on the battery charger when the starter kicks in. Why risk an expensive charger?
Apr 8, 2014
12
Thanks everyone for you recommendations and comments. That helps a lot. I too have made a checklist but the one offered here is fantastic! I will definitely use it!! I have been starting the engine every two or three days (copying someone else) and let it run for 5-10minutes before shutting it down. So now begs the question...should I do this? It just seems to me that if I don't do this and wait a week without starting, it seems to be more difficult to get her going again. Maybe that is just the way diesels are? She runs like a champ so I definitely don't want to mess that up. On another note, I took her this weekend and she sailed beautifully. I took along a few people that had never been on a sailboat before and it looks like they are now "in love". :) And I even remembered to unplug before I launched!! YAY!! Thanks again for your help!
Oct 6, 2009
129
Newport Newport 28 MKII Jacksonville, FL
As others have mentioned running your diesel for 5-10 minutes every few days is hard on it. If it is hard to start after sitting a week, you may have an air leak in the fuel system and in my experience, those get worse and will probably cause a no-start situation, usually when you need the engine the most.
Oct 29, 2005
2,362
Wonder if there's anyone sail off with shorepower still attached more than twice?
Once bitten, twice shy ;)
Apr 11, 2010
976
Definitely DO NOT start and run 5 to 10 minutes. You are not doing your engine any favors. In that time it does not get hot enough and unless you are putting it in gear and running it hard you are running risk of engine damage via soot build up.
