I am planning on adding a water hose bib so I can use shore water when my boat is in slip. I planned to have the shore water enter the system after the pump so I can take advantage of the city's shore pressure. After reading Peggy's article about cleaning and keeping the water tank clean and fresh, it occurred to me that having the shore water cycle through the tank would be ideal. The project then raises sesveral questions:
1. Where is the best place to locate the hose bib? I mused about modifying the tank filler cap to include a bib, but that compromises it's flush mounting and assumes I can solve question 2.
2. Can I have my cake and eat it too by having the shore water go through the tank and also by pass the pump? I suppose that would require installing a two positiion diverter valve of some kind that was readily accessible to direct the water from the tank to either the pump or directly into the water flow system.
3. Do I need something to reduce the shore water pressure?
4. Are there check valves normally installed in the system already? Where would they need to be added?
5. If someone has accomplished this, would they mind sharing a rough plumbing diagram with me?
