Shore water connection
Don
Planning to install a shore water connection with check valve and pressure reducer, however, I'm not sure where to tie in. I've been told to do it just after the pump output, however, that takes much more effort than simply connecting to the cold water side of the cockpit shower line. I see no difference and don't want to make this project more difficult than necessary. Can someone let me know if it makes any difference? Don Illusion
Steve
Cold water supply
I hooked the shore water regulator/input into the cold water supply off the shower of our 376 and it's been working fine. We always turn off the water from the dock when not on the boat.
