I have a new fresh-water intake electric macerator toilet. I have chosen, rightly, or wrongly, to use one-inch Trident-premium rubber hose for the outlet to the toilet to the holding tank and to the overboard discharge. If possible, I'd like to use the same type of one-inch rubber hose to the deck discharge coupling (which I understand normally takes a 1 1/2 inch hose).
Is it possible to run a one-inch hose to the deck fitting with an adapter so that the one-inch hose can be connected directly to the deck fitting? Would this cause any problems?
Also, what size should the holding tank deck vent be?
The holding tank is a rondo plastic tank.
Ken
Ken
