Shore Power
37
Hunter 260 Sylvan Lake
Can anybody advise on what shore power kit assembly works best for a 2005 h260, I’m considering installing:
- Standard bulkhead stainless plugin
- 2 lead Marine battery charger to keep both marine batteries topped up when plugged in
Would like at least 1 electrical outlet but I don’t know if i should put a inverter off the 12volt system or a 120 outlet prior to the charger?
Thanks in advance
DJN51
Oct 26, 2009
377
Hunter 23.5 East Chicago In
Try EZ AC DC.com.makes a kit put it on my 23.5 hunter .Easy install couldn<t buy parts for what kit cost
37
Thanks for the excellent advice, it is exactly what I was looking for and it is currently reroute to my address, including a Pro sport marine battery charger.
This is what forums are intended for, people with the right knowledge sharing it with others.
Thanks very much again.
Bruce
Deucer
Oct 6, 2008
157
Hunter H260 Keesler AFB Marina
I want shorepower for other reasons than battery charging. I've got a 5 watt solar panel running through solar panel regulator that keeps my battery topped off very nicely (haven't had the battery on a charger for two years). Works while the boat is on the trailer or in the water.
-na -NA Anywhere USA
Lucky Day;
send me a private email with your phone number as I pioneered shore power on the 260 and quit counting the number of shore power systems I insatalled as a former dealer. Whatever you do, please add a GFI on that circuit.
crazy dave condon
