That is the #1 most important thing in the electrical department of your boat.I don’t think that my boat has a 110-12 battery charger.
Without an AC charger, you will go through flooded lead acid batteries like disposable dry cells in a flashlight and that means $ $ $ $ $ $ $.
I'd find it hard to believe that you don't have an AC battery charger. Could the PO have removed it before he sold it? That's criminal!
You can't run fans, or any other modest conveniences without a charger and/or AC outlets. Does your C30 not have outlets either?
Those are very debatable comments . I haven't used an AC charger in 12 years or more and my two mid level quality 110+/- AH batteries typically last five years or more. I use a 25 watt solar panel for battery maintenance and add 50 watts solar for when I go out on short cruises (typicallly six or seven five night trips per year) . Obviously I don't run a refrigerator with that but there is everything else; LED lights, stereo, phone charging, nav instruments etc. I'm in southern California. In New Brunswick I might guess it doesn't get hot enough to need a lot of amps to run fans let alone an air conditioner.Install 110ac battery charger.
AC power allows you to run a vacuum while in port. You can run an electrical heater to take the chill of the boat. The electrical pressure washer and the charger for battery powered tools both use AC power. Then of course there is AC power for an air conditioner when at a dock in the heat of the summer.
Just a few of the possibilities.
I don’t have dock power, so I’ll be adding solar shortlyThat is the #1 most important thing in the electrical department of your boat.
This is my first boat, so I was expecting some sort of crossover ability between the AC and DC panels. My boat was built in 1985, so maybe I shouldn’t be surprised that it doesn’t. I plan on adding 600 watts of solar this off season, so I’ll probably skip on the AC chargerThose are very debatable comments . I haven't used an AC charger in 12 years or more and my two mid level quality 110+/- AH batteries typically last five years or more. I use a 25 watt solar panel for battery maintenance and add 50 watts solar for when I go out on short cruises (typicallly six or seven five night trips per year) . Obviously I don't run a refrigerator with that but there is everything else; LED lights, stereo, phone charging, nav instruments etc. I'm in southern California. In New Brunswick I might guess it doesn't get hot enough to need a lot of amps to run fans let alone an air conditioner.
When I want to run a 110 vacuum or a power tool I do it at the dock and plug the boat into the shore power and use the 110 outlets on the boat. I'd also do that if I wanted to run a heater if I ever needed to.
It does have outlets. The boat has been living on a mooring for over a decade, so I don’t think that the PO bothered to try the shore power connection. I plugged in into my house power yesterday, and was expecting more.I'd find it hard to believe that you don't have an AC battery charger. Could the PO have removed it before he sold it? That's criminal!
We’re on a mooring, so will probably go with solarThat is the #1 most important thing in the electrical department of your boat.
There are two ways power can be transferred between the AC and DC sides.This is my first boat, so I was expecting some sort of crossover ability between the AC and DC panels. My boat was built in 1985, so maybe I shouldn’t be surprised that it doesn’t. I plan on adding 600 watts of solar this off season, so I’ll probably skip on the AC charger
If you spend much time away from your mooring, a battery charger MAY be a nice luxury when you pull into a moorage with dock power. Gives you the opportunity to get the batteries up to 100% SOC so you're ready to anchor out for a few days. Just a thought.I don’t have dock power, so I’ll be adding solar shortly
