Shore Power Installation
K
Keith
I would like to install shore power on my 26X. I am a bit nervous about putting a hole in my boat. Can anyone put my mind at ease and give me some tips? Please.
Timm Miller
Beer
Plan out your work........install it in your mind over and over again.......it goes really quickly.......3" hole on the outside and it's over......inside work takes a bit more planing and cutting.
Doug Rodrigues
Suggestion......
Suggest that you drill a small pilot hole first from the outside (i.e. the drill bit only, on the hole saw) and then remeasure your position on the inside. If any adjustments to the larger hole have to be done, that option is still available. Sometimes a permanently installed bracket, wire, or line is hidden under that upholstery. I learned the hard way once, on an airplane! Just don't rush anything.
