What I did was
install a "battery charger inlet" in the area next to where the engine control/alternater cables go through the transom, into the stern area behind the bulkhead doors. I then wired that up and ran the wire (12/3) all the way through the galley to just in front of the sink cabinet in the starboard settee above the sole by a few inches (~5-6") and wired it to a GFI that has a little green LED that is lit when you have power connected. This way, when I'm on the hard, I can plug a regular extension cord into the charger inlet. For actual shore power use I have one of those shorepower pigtails that converts the boat end of the cord back to a regular extension cord type female plug.FWIWMVVMTom M.
