Dear Fellow Hunter Owners
I am renewing the Shore Power AC Breaker on my 1980 Hunter 27. The original breaker has no indication of the amperage value, as the sticker with this information has worn and fallen off.
My question is, what amp breaker should I use to replace the old one. I have this much information to offer
1. It was a three pole breaker. The black (hot) ran to the top pole. The white (neutral) ran to the middle pole. And the green (ground) ran to the bottom pole, which I assume is a reverse polarity trip coil.
2. The cable coming into the breaker from the shore power outlet is 10 gauge triplex marine grade. coming out of the breaker is a terminal bar connected by 10 gauge wire. Out from the terminal bar, runs three lengths of of 14 gauge triplex Marine grade, that lead to three individual outlets.
That is all the information I have. My question is what size breaker do I use. Practicality tells me I want at least a 30 amp breaker, being that, at shore I may be drawing 20 pluses amps with my inverter running and other gadgets. But good sense tells me that the 14 gauge triplex running fromm breaker to outlets should be protected by a 15 amp AC breaker. But that doesn't seem like it would be enough.
I would appreciate any information on the matter. I realize there is a many of you folks with a wealth of knowledge and a sea of information will flood in. But if possible can the input try and remain on topic, as these forums have a tendency to fly off the handle. Again, what size AC Breaker should I use for my shore power? Thank you for you diligence and steadfast dedication. Happy Sailing.
