Shoaldrafter took these pictures of Strider going by a couple days ago. I believe they were taken just before I crossed into South Carolina. There was quite a bit of current and I was really pouring the coal on to get anchored before dark.
It's pretty unusual that he got that shot. I usually spend not more than 10-15 minutes a day at the helm. I'm normall sitting forward in the cockpit or standing in the companionway with the autopilot remote in my hand.And there is Roger, poised like that bronze statue of the sailor looking to the sea.
Yes. It's too long according to an article by and experience ICW cruiser I read recently but can't find now. The author favors short 2 x 4's which are cheap and easy to replace.What do you have on your toe rail between the pulpit and the first stanchions? Fender Boards?
During Sandy I found our fender board to be a problem as the water rose and fell. It got twisted around the fenders and squeezed against the hull. It also caught one of the dock lines and chafed it a bit. I'm saving it for times when the pilings might have a protruding bolt or nails.I've also used it as a gangway in a strange docking situation where I couldn't get close enough to the part of the dock that connected to shore.
It's a little clumsy to set up but stowing is quick, fitting between the stanchions as it does. It's a good compromise for me but, if I ever get a permanent crew, I'll probably switch to a shorter and lighter board.
You will need a different forum to advertize for a rich, female sailor...Yes. It's too long according to an article by and experience ICW cruiser I read recently but can't find now. The author favors short 2 x 4's which are cheap and easy to replace.
However, I find that docking single handed in current, it's nice to have a long board because the boat often moves a bit before I can get spring lines set up and the other lines on. The board would be too heavy and clumsy if it were 2 x 8 but it's 5/4 thick (actual thickness 1") so it isn't a lot heavier than a 2 x 4 of the same length would be.
I've woken up in the middle of the night to find the boat heeled over ten degrees. It was rather disorientating as I was trying to figure out why everything seemed strange struggling into get my mind fully awake. The board had caught under a piece of dock structure. This is the reason you don't want to tie the fender board to lifelines. Even fenders can get caught. I had to cut the first line to get the board free.During Sandy I found our fender board to be a problem as the water rose and fell.
-------------- // ----------------I've woken up in the middle of the night to find the boat heeled over ten degrees. It was rather disorientating as I was trying to figure out why everything seemed strange struggling into get my mind fully awake. The board had caught under a piece of dock structure. This is the reason you don't want to tie the fender board to lifelines. Even fenders can get caught. I had to cut the first line to get the board free.
It's just one of those things. I try to look now for piling structure that could snag the board and sometime lay up against a different piling.
It's not the dating sites, that's for sure. Just for fun, I did some research. Google "Is #####.com a scam?" for any one of them, including the high profile ones that advertise on TV. After all, if they find you a match, they won't be getting your money any more.Please tell me just what forum that is, as I am a widower of 76 in good health and proud owner of an O'day 22 , close quarters ay?
------------------- // -------------------Hi there Shoaldrafter, can I assume that from Rogers comment "if I ever get a permanent crew", that he is single and you think he would benefit acquiring a female mate from a proper forum. Please tell me just what forum that is, as I am a widower of 76 in good health and proud owner of an O'day 22 , close quarters ay? Maybe she will have a larger boat like zeehag's. There must be a Single Sailors Forum somewhere, ay ?
I have sailed single handed, but it is more fun with some one or two else aboard. With dreams and hopes of returning to Charlotte Harbor and cruising beyond, I will surely need help anchoring and other task requiring more than two hands.
David S
whats with the attached image ?
Google is your friend.snip-. There must be a Single Sailors Forum somewhere, ay ?
David S
