F
Fine As Frog's Hair
I recently purchased a 1977 O'Day 22 with a shoal keel. Does any one have any specifications on this model 22? I do know that the standard specs I found do not correspond to the actual specs of the boat. For instance, the mast is supposed to be 27ft long, but mine is only 23'-6". I just purchased a new main sail, and purchased is by my measurements, but the sail loft sent me one to fit an O'Day 22 and it is the correct luff lenght - 20'-3".I am not sure how much the boat draws? I measured about 30" but that is based on the waterline stripe that the factory put in. Is this correct. I am going to need this information when I put in. There is a lot of shoaling in the area!I have a 15 gallon water tank in the bow under the V-berth. Is this standard? The only fill I found was on the top of the tank which is as un-handy as hell! Has any one made a modification to allow for filling from the deck?Is there a bilge in the boat? I found a small opening in the aft section of the cabin, about 2" in diameter. It is the only place I found any opening to get to the ballast area. It is too narrow to put in a bildge pump, but I need one since the boat will be in the water.I had to do extensive remodeling! Replaced the ports with a solid tinted plexiglass cover, both the inside and the outside, giving the boat a more modern look. The old ports were broken and leaked. I also added a depth sounder, which is very neccessary in the areas where I have to motor and sail. I also added a Plastimo Bulk Head Mount Compass. I tied the rudder and the 9.9 hp Mariner Outboard together, so I can use the motor's extended tiller to drive while under motor power. The linkage is easily removed giving the the rudder freedom to move when under sail. I am in the process of re-wiring the whole boat. I should be finished with it this week and I plan to launch her this weekend - 4th or July weekend! She is called "FINE AS FROG'S HAIR!" She has a stylized frog on her side and a cast iron one on the trunk where the O'Day logo used to be. I did not take it of. I would be proud to carry the O'Day logo!If there is any one out there that can help me with my questions, I would be greatful.Sincerely,Paul - "Fine As Frog's Hair"
