ships, shoes, sealing wax, 37 C's
776
Hunter 37 cutter Blind River
A few questions for you experienced 37 Cutters: Does anyone have an old head for a 3QM30? Has anyone advice on exchanging the original alternator for the 3QM30 with a high output one? Any updates on the thread of yankee vs. genoa style headsail or larger than original?
A
avalonduet
alternator
I replaced the Hitachi 35A with a Powerline 120A. The problem was adapting from the two-ear mounting to a one-ear one. I think if I had it to do again, I'd look into mounting the Alternator on the Stbd side of the engine, to even out the belt tension, even doubling the engine pulley so I could drive the water pump and alternator separately. Depending on the size of your battery bank, it is a very good modification. Don't forget, you''ll probably want a smart alternator regulator too.
May 31, 2007
776
alternator
Thanks for the response and good advice. Hopefully more ideas will be coming soon.
richard shelby
yamnar alternator
Yanmar 100 Amp alternators on ebay I installed a Hitachi 60 Amp on my 1981 3QM30, no real problems. If your go up to 100 Amps your need to double the drive belts. Also you will see a drop in shaft power when that big boy calls for Amps.
