Don Guillette
Shifting Through The Sail Trim Gears If you own or have owned a stick shift car, have you ever downshifted? Of course you have and why do you shift? The answer is because the driving situation changed and you wanted to keep your momentum. Same thing on the water - the direction and speed of the wind probably changes every 5 minutes. Do most cruisers adjust their sail trim during these changes? Probably not, which is fine, but maybe they would like to at least know the procedure in the event they found themselves in a situation where they really had to make an adjustment because the puff was so strong that all the drinks and snacks fell on the cockpit floor!! When your half way up the Baker grade on your way to Vegas, do you wait until the engine lugs down before you shift? Probably not. You shift before the engine tells you to and it is the same way on the water. You want to change your sail trim BEFORE the wind change reaches you and generally you can see it coming. There are two ways to react to a large puff of wind. The first way is to wait until it hits you and the boat starts to heel over and then madly dash around to make your sail trim adjustment. You would drop the traveler, ease the mainsail and jib, which would de-power the boat and get it back on its feet. Then you'd have to re-trim the main and jib and tighten the boom vang and Cunningham. Using this method and relating it to your car on the Baker grade, your engine just lugged and you REACTED to the situation. Here's a better method. Most of us can see the puff coming just like we see the hill grade approaching. Next time you see one coming, try this. Do 5 simple things - tighten your boom vang, tighten your cunnigham (if you don't have one you should consider one because it is easier than adjusting the halyard), ease down the traveler, and ease out the main and jib sheet just a bit. When the puff hits, your boat should stay on its feet. After the puff hits and your in the higher wind, merely trim in the main and jib just a bit and your boat will power through the puff. After the puff hits, go back to your original setting. Experiment and see if this works for you.
