Dawn
After discovering & fixing a prop strut alignment issue, our engine will now die when shifted into gear. It runs fine in neutral, is firing on all 3 cyl., idle seems high enough. You can turn the shaft by hand, so alignment/tightness does not appear to be an issue... It has a Max prop (3 blade feathering) but that seems to be working alright. We found that the engine will crank & briefly run if started while in gear (!) but it dies almost immediately. It motored from the slip to the sling fine, no tranny issues noted. The mechanic thinks possible fuel gov problem$$$, but it ran fine before. Any ideas what could be causing this? The engine is the original-- Universal M25... Any help is appreciated!
