Shifting issue on my '96 Evinrude 8hp.
Dec 29, 2021
89
Catalina, Tanzer C 22, 16 10910 Starr SC
I finally gave up on the 7.5 Mercury motor that came with my '82 Catalina C22. I traded for a 1996 Evinrude 8 hp and it runs great for the most part. I was finally able to get the Catalina out of her slip and take it for a spin. The problem I have is in the shifting. Although the motor is running very well, it is a bear to shift. I thought about putting some sort of longer handle on the shift lever to give me some extra leverage but that doesn't really solve the problem. Any suggestions?
dmax
Jul 29, 2018
1,257
Telstar 28 Buzzards Bay
I had the same engine at one time, it should not be difficult to shift at all. Don't add leverage, you want to find the problem and fix it - follow the mechanism to see where it's binding. The shift cable is a likely culprit.
Nov 6, 2006
10,152
There usually is a grease fitting where the shift lever turns , just above where the leg mounts to the cowl. Try giving that a squuirt of lithium grease.
