sheets
C
Cameron Root
I am using the spinnaker sheets that came with it for both spin. and genoa. I find using a suncor snap hook for changing between the two is clunky on the more familiar genoa. Should I cut the sheets and install two snap shackles for less fouling ? If so can you recomend a size and or make for smoother tacking?
Timm Miller
Spinnaker Sheets
Should be 1.5 times the length of the boat....make sure the windward sheet goes in front on the forestay.....gybing a spinnaker takes a lot of practice.
