Shaft zincs inside the engine bay?
Oct 9, 2008
1,742
Bristol 29.9 Dana Point
I saw a pic once of a shaft zinc attached to the shaft inside the engine bay. Thought it a silly anomaly.
Then I saw another, and another.
Doesn't the zinc need to be touching the water, to, you know, act as an anode?
Have I been stupidly keeping zincs under the boat when I could have been servicing them in the engine bay the whole time?
Nov 6, 2006
10,247
Zinc must be in contact with the water to protect the propeller.. They may have been putting an additional one on dry shaft to help with corrosion around a weeping stuffing box?
Some have put shaft zincs inside the boat as cheap protection against losing the prop shaft if it separates from the coupling. The shaft can only slide as far as the space between the zinc and the stuffing box. A better choice might be a SS Shaft Collar (https://www.mcmaster.com/#shaft-collars/=18t2na0) but the zinc is cheaper. A 1" 316 SS is over $30, a zinc under $10.
Feb 8, 2014
1,300
Columbia 36 Muskegon
I once towed in an old Chris Craft motorboat with the shaft pulled out. It hit the rudder and stopped, but there wasn't enough shaft sticking out of the stuffing box to grab and pull it back in. A shaft zinc or hose clamp would have prevented it from happening.
Ted
Jan 26, 2005
1,280
A shaft zinc is often placed very close to the bellows of a PSS dripless shaft seal. It would prevent the bellows from extending if the part that is attached to the shaft became loose. Loosing pressure between the polished mating parts would compromise the watertight seal.
Likes: sailboatracer
JerryA
Oct 17, 2004
550
Hunter Hunter 170 Sandusky Bay, Lake Erie
That sounds like something I should do.
