A
A.J, Wortelboer
When hauled out this fall I noticed that the prop shaft is wearing at the hull opening the cutlas bearing and strut is fine. Inside the shaft coupling and packing look great. Could the YSM 12 mounts be bad and have let the engine drop down to where the shaft is now rubbing on the thru hull plates lower portion. It seems to have rubbed enough that the diamiter of the shaft is getting a deep cut down of size at the opening as it exits the the hull plate. Has any Cheribini owners ever had this problem.
