shaft, cutlass and packing
The cutlass has some rubber components that do vulcanize and disintegrate over time. In my case several years back...I heard a thunk..thunk when the shaft turned and knocked on the strut housing. I used 3M5200 on the strut to hull/boltholes. And check the condition of your thru hull bolts on that strut plate- replace them - as one of mine had taken to rust(galvantic action)in a SS soft spot and began to bleed thru (read as" slow leak")- SS bolts are not created of equal quality.Repacking box- I've used the teflon packing and had been very happy with it...get the right diameter "engineered fabric". Pick out( I used a dentist's pick) the old packing from the housing, insert three rings of the new fabric - ring seam inserted to a 1/3 offset from the prior ring. You may not need a new box but if you do, there are 2 diameter measurements you need(especially the aft side)where theres a hose & clamps to the hull/shaft receiver (which may be part of the assembly from Hunter). Contact Hunter for details.Careful -Don't over tighten the packing box. When you spash-in, hold the boat in the sling for a while, watch the box for leaks, run the engine (while in sling)a little while and then adjust the tightness again once the box has "juiced" itself up with seawater. Check again periodically as the material takes a set.
